Max Knobel Geschrieben Montag um 15:17 Geschrieben Montag um 15:17 (bearbeitet) Eine ganze Reihe von Infos. Coming soon: Fuel & Load Adjustable fuel and load weights in all airliners and several small aircraft New flight assistant that checks values affected by changes in fuel & load Overhauled flight assistant menu and "Auto cockpit" split into categories Comming soon: New Boeing 787-9 Dreamliner We're adding a brand new aircraft to Aerofly FS, the Boeing 787-9 Dreamliner! The 787-9 is shorter than the existing 787-10 aircraft and has been very popular with airlines in the real world. Our 787-9 for Aerofly FS features over 35 different airline liveries. Comming soon: New Aircraft Carrier That's right, we're adding a functional aircraft carrier in Aerofly FS! With the F/A-18C you can now perform a catapult launch from the deck of a moving aircraft carrier, extend the arresting hook and land back on the flight-deck. Because the ship is moving and because the runway is angled to the side landing on the carrier is not actually easy but it can be great fun! Especially at night... New moving aircraft carrier New catapult launch New arresting hook landing Major F/A-18C overhaul, cold and dark and adjusted flight-controller Comming soon: New Airbus A320neo A new aircraft is being added to Aerofly FS, the Airbus A320neo! The A320neo (new engine option) is derived from the A320ceo (current engine option) but it differs in many aspects and has seen many improvements. We've gone to great lengths to integrate these real world changes into our Aerofly FS simulator aircraft as well, see the long list of differences below. Two new engine variants: CFM LEAP-1A26 and PW1127G-JM with new custom engine sounds Increased maximum takeoff weight (79,000 kg), higher max landing weight (MLW), higher passenger capacity Decreased fuel flow, lower noise and emissions and increased range Sharklets as standard Over 55 airline liveries Black mask around the windows (on select airline liveries) Am einfachsten hier komplett anschauen. Neuheiten | Aerofly FS Guten Flug Max Bearbeitet Gestern um 08:42 von Max Knobel Korrektur Zitieren
Max Knobel Geschrieben vor 1 Stunde Autor Geschrieben vor 1 Stunde Das Update ist jetzt verfügbar! Es wird beim nächsten Start automatisch installiert. Max Zitieren
