[Video] 22.01.19 | Bomber T22M | Murmansk | crash during landing in blizzard conditions
Niko
Seit gestern kursiert auf Diversen Videoseiten ein Video vom Crash eines T22M Bombers.
Leider sind alle Angaben auf Russisch und mit dem IPad ist es mir nicht möglich den Text zu kopieren um ihn von google übersetzen zu lassen.
Kann vielleicht jemand hier Russisch? ?
Bearbeitet von Niko
3 Tote, ein Verletzter. Landung verkackt.
https://sputniknews.com/military/201901271071854762-russian-tu22m3-bomber-crash-landing-video/
Zitat
A horrific crash took place in the Murmansk region and video has emerged showing the bomber’s approach of the landing site in near-zero visibility and the moment the plane snapped in half, exploding.
The video appeared to be recorded by one of the servicemen at an air base near the city of Olenegorsk, according to RT, and has since been leaked online, showing heavy fog covering the area during the January 22 incident.
During the landing the strategic bomber literally split in two while landing in Olenegorsk, with its cabin catching fire, stopping further than the rest of the plane.
Two of the crew members died during the crash, and the pilot later died of his wounds.
Three of the four-pilot crew died on the spot, while the commander miraculously survived. He was urgently hospitalized with serious injuries. An investigation has been opened to determine the cause of the crash.
The fatal flight which took place in blizzard conditions was a routine training mission, according to the Russian Defense Ministry, the bomber wasn’t carrying any weapons during the incident.
The Tupolev-22M3 is a supersonic long-range strategic and maritime strike bomber. This particular aircraft was produced 33 years ago but has since undergone a major overhaul in 2012, and was reportedly further due for a full modernization.
sieht aus wie eine "no flare" Landung….Carrier tauglich dürfte dieses Fluggerät von der Struktur her jedenfalls nicht sein..
Gerd
  • Gefällt mir 2
  • Danke 1
Gerd
Eher nicht nein?
  • Gefällt mir 1
  • Danke 1
Wie schlecht die Sicht auch war, er (oder sein A/P) traf jedenfalls die Piste. Es macht den Anschein, dass das Rumpfvorderteil in dem Moment abbrach, als das Hinterteil von der Fahrwerksfederung wieder nach oben katapultiert wurde. Entweder war die Sinkrate zu hoch oder die Dämpfung des Hauptfahrwerks zu schwach. Die Massenträgheit des Rumpfvorderteils (mal seine Beschleunigung) überstieg jedenfalls die Biegefestigkeit der Rumpfröhre. Ob er die Sinkrate wohl wegen mangelnder Sicht nicht rechtzeitig verminderte? Oder hatte er etwa ein Problem beim Ausfahren der Flügel? Im Video scheinen die Flügel allerdings eher in einer vorderen Lage gewesen zu sein.
In Bern ist mal ein Lear-Jet bei so schlechter Sicht gelandet, dass der Pilot keinen Flair einleiten konnte, sondern erst beim Knall merkte, dass er am Boden war. Die Federbeine seien durch die obere Beplankung durchgedrungen, doch habe das Flugzeug repariert werden können.
Stefan
Bearbeitet von teetwoten
Videos von anderen Landungen zeigen, dass die TU22 normalerweise geflared und butterweich auf die Piste gesetzt wird. Das scheint kein Flieger zu sein, den man einfach so auf die Piste "klatscht". Beispiel:
https://youtu.be/o-osnXmmAlo?t=51
In russischen Medien kursieren weitere Details. Demnach war die Sicht so schlecht, dass der Flugleiter der Maschine befohlen hatte, zum Alternate zu fliegen (Sichtweite von 3km und 300m Wolkenuntergrenze war unterschritten). Der Regimentskommandeur war aber im Tower anwesend und hat den Flugleiter überstimmt. Die Landung wurde dann doch genehmigt.
https://www.murmansk.kp.ru/daily/26933/3983422/
Bearbeitet von QDM
links
  • Gefällt mir 1
  • Danke 3
Immer schlecht wenn höchstrangige Militärs, mit zu viel Gold bestickt, meinen alles und jedes besser zu wissen..
Erinnert mich stark an den CFIT der polnischen TM154M in Smolensk 2010 damals..
Sehr schade, so ein tolles Fluggerät.
jens?️
vor 21 Stunden schrieb QDM:
Liegt Murmansk eigentlich südlich der Alpen? ?️‍♂️
Tja, so ist das mit den Stablinien-Organisationen.
Erinnert mich an eine Begebenheit als Soldat:
Generalstabsoffizier: "Bringen's das in Ordnung - SOFORT!!"
Ich: "Aber der Herr Oberst hat gesagt..."
Generalstabsoffz. (selbst auch Oberst): "WAS DER HERR OBERST GESAGT HAT, IST MIR WURSCHT!!"
1:1 wiedergegeben ?
Johannes
Bearbeitet von Phoenix 2.0
vor 1 Stunde schrieb sheckley666:
Meines Wissens nicht, aber ziemlich weit östlich von Moskau.? Aber was sollte südlich der Alpen schlimmer sein als in Rußland? ??
Manfred
PS: wer im Zeitalter der Globalisierung nicht mehr an die Bedeutung orographischer Grenzen glauben mag, frage mal in Bayern  nach dem Weißwurstäquator.....?
Bearbeitet von DaMane
hehe.. Frank und die "vernunft* der pure" (*Staatlich bezahlte) sind ja nur neidisch auf das seit 6 Wochen andauernd fantastische Wetter hier im Südticino, Sonne - Blau - 8-12Grad, plus ? natürlich..
Freude?herrscht
?jens
Frank Holly Lake
Uff.so schlimm sah die Landung die Landung gar nicht aus.
Manches Verkehrsflugzeug habe ich härter landen sehen, ohne das es zerbrach.
Nase abgebrochen hecklastig , Triebwerke laufen weiter
und schlagen  im Bereich der abgebrochen Nase auf,  mehr Pech kann man nicht haben. .. Tragisch
RIP  Frank
Is so...
mag etwas härter gewesen sein, OK…aber ,zumindest was man auf dem Video sieht…SO eine Landung hält jeder westliche Airliner oder Bizjet ohne bleibende Schäden aus..
das ist alter Sowietschrott…und Training werdens auch wenig machen..der Putin steckt ja Alles in neue Nukes…(nur  um an der Macht bleiben zu können)
die arbeiten einfach diese Bomber jetzt bei Trainingsflügen auf..
tragisch für die Crews und ihre Angehörigen…aber so Sachen waren in Diktaturen nie anders..
Gerd
Frank Holly Lake
Ich habe da zu wenig Kenntisse .
Zur Erinnerung:
So um das jahr 2000 stürze eine F15 ab.
Der Pilot konnte sich retten, Schleuderistz.
Das Cockit war abgebrochen beim normalen Landeanflug.
Erkennisse der US Air Force ergaben, des es sich um Materialermüdung handelte.
Die Zellen alterten schneller als erwartet und berechnet.
Einige wurden ausgemustert, viele in dem Bereich überprüft und am Ende sogar verstärkt
Sollte man daraus schließen, die westliche Mc Doof Technik ist nur Schrott?
Wir ( ICH) wissen nichts über Korrosion, Materialermüdung Überprüfung/Wartung oder Konstuktion der T 22M
Grüße Frank
vor 5 Minuten schrieb Falconer:
Is so...
Na ja ?! Da auch in Rußland nicht jeden Tag Flugzeuge zerbrechen, könnte man daraus den Schluß ziehen, die Piloten dort i.d. Regel schönere Landungen machen und das Material weniger strapazieren ?
vor 10 Minuten schrieb Falconer:
Gerd
Die russische Militärtechnik stand eigentlich immer in dem Ruf, zumindest überdurchschnittlich robust zu sein. Sollte sich das so krass geändert haben?
Manfred
Erkenisse der US Air Force ergaben, des es sich um Materialermüdung handelte.
Ja, ist aber ein ganz anderes Thema…die Doppelstitzer von den F15 habe ein bissel ein bissel ein Problem mit der Zeit bekommen strukturell…klar grosse Loads und in Trainingsflügen oft auf max G-Loads ( im operationellen Einsatz machen die ja kaum G Loads ausser bei einer evasive Action von einer SAM..in Dogfights kommen die nicht, die schiessen Alles vorher Beyond Visual Range air-to air ab.. aus dem 1G Cruise auf dem Autopiloten..)…naja habens frische Cockpitsections draufgebolzt…mit mehr structural life..hat was gekostet , klar…aber Geld für sowas hätte ja Russland gar nicht..haben ja Putin & Co dem Land die letzten 20 Jahre gestohlen…liegt bei uns und in der Schweiz und off-shore auf Nummernkonten..
Gerd
11 minutes ago, Phoenix 2.0 said:
@Gerd: Alter - manchmal schreibst scho an ordentlichen Stiefel zamm... ?
Johannes
Wieso…?
A Falcon bricht ned auseinand bei so einer, zugegebenerweise, eher sportlichen Landung…nur als Beispiel jetzt..
keine…weder die älteste F20 noch die neueste F8X...
Gerd
Bearbeitet von Falconer
Ich meinte Aussagen wie "Training" und sonstiges Bashing...
Wenn man die wirkenden Kräfte betrachtet, dann ist das eben ein anderes Design, als eine Mystere oder so... die Fahrwerksgeometrie und der "Hebel", der auf den vorderen Teil wirken anders. Ich kenne mich da zu wenig aus, aber ich denke, das es zu einfach ist zu sagen, "mit einem westlichen Airliner oder Bizjet wäre das nicht passiert". Mit der Valkyrie (wenn damals in Dienst gestellt worden wäre) hätte das auch passieren können... imho. Solchen Designs kann es ab den Limits "das Genick" brechen...
Johannes
Sorry Johhanes, nein, es gibt nur gutes Design und Material, oder schlechtes Design und schlechtes Material..
egal ob zivil oder Militär
Gerd
P.S.: Dass der Sowietstaat ein Mangelsystem war, ist uns klar, oder?…unter den Umständen hat damals die "Aristokratie" der russischen Flugzeugdesigner eh Beachtliches zustande gebracht…Kunststück, die mussten immer improvisieren ( das prägt)..haben ja nix gehabt..und das haben sie gar nicht so schlecht gemacht…aber die Überbleibsel dieser alten Sowiettechnologien haben in der Luft nicht einmal mehr den Funken einer Chance, z.B. gegen die ältstest , aber upgedated F-16 oder Mirage 2000 zu überleben…von einer Rafale gar nicht zu reden...
und, dass die Dinger jetzt schon bei einer härteren Landung zerbröselt…naja…iss a Wunder?
..kurz vorm Aufsetzen heulen die Triebwerke auf: hat es diese zusätzliche Beschleunigung noch verschlimmert!? Oder ist das in der Situation bedeutungslos?
Eigenartig, wie das vordere Teil wegknickt... vielleicht eine Schwäche im Design oder die Dinger stehen da oben zu viel in arktischen Wetterbedingungen.
Grüße
Chris
kaum, war etwas zu spät, was die Power betrifft, und ein bissel zu spät was den Round Out betrifft..( respektive man sieht nicht einmal den Ansatz eines Flares..)
die (schlechten) Sichtverhältnisse mögen da eventuell ( oder sogar sicher) ein Faktor gewesen sein
ungemütliche Gegend dort um die Jahreszeit...
Gerd
vor 18 Minuten schrieb Falconer:
Gerd
Sehe ich auch so:  Je nach Jahreszeit...
- "Ungemütliche Gegenden"    gibt es jeweils überall,   in jedem Moment,    global gesehen:   je nach Breiten- und Längengrad.
Habe grossen Respekt für professionelle Piloten in aller Welt.
Richard
vor einer Stunde schrieb Falconer:
Is so...
Gerd
Gerd, so sehr ich deine normalerweise fundierten Posts schätze - aber was du da so über die Russen rauslässt, ist, excuse my french, unter aller Sau. Die Kiste da schlägt mit Gleitwinkel 1:Klavier bei geschätzt mindestens 350 Sachen auf. So heftig sind nicht mal die Spatzenschüttler runtergekommen - und du behauptest ernsthaft, das würde jeder Westflieger problemlos wegstecken? Träum weiter, Trägerflugzeuge vielleicht, aber kein Otto-Normalflieger, schon gar nicht GA-Mühlen.
https://www.youtube.com/watch?v=jaqRx3SV-k8
Das ist nicht mal etwas politisches, sondern schlicht ignorant. Wenn man den Russen etwas vorwerfen kann, dann ist es allenfalls, dass sie ihren Kram immer viel zu massiv und damit zu schwer gebaut haben und der dadurch unter West-Bedingungen kommerziell nicht konkurenzfähig war/ist - aber nicht, dass deren Zeug nix aushält?
Ach ja, versuch das mal mit ner Dash...https://www.youtube.com/watch?v=VbVmYrtMxps
  • Gefällt mir 1
  • Danke 2
